Minerelli based drag scooter build
ottoman
Postby ottoman » Tue Aug 21, 2012 12:06 am
Thought I start a build thread for my drag scooter.. seems to be some interest
This is it currently... I would say the finished product but race stuff is never finished :D
ottoman
Postby ottoman » Tue Aug 21, 2012 12:17 am
We (my son and I) started with a old Spree, stripped it down and cut the frame tube at the rear mount.
We had previously decided on about a 55 inch wheelbase with a Zuma 2 stroke motor.
So it needed a longer lower tube. I got he closest american size tubing and machined up a inner tube to adapt the two differnt size tubes. We slide it in and drilled a couple holes and rosset welded the piece in and then finall welded the tubes together. Kid really getsa mad when the frame breaks in half on the track so I felt this was the best way to join the tubes 8)
ottoman
Postby ottoman » Tue Aug 21, 2012 12:23 am
Next we needed to build the rear frame section so we welded on a cross bar, drilled some 1 inch holes and bent up the two lower motor mount tubes out of 1 inch .065 DOM tubing.
We went all the way through the tube so I could weld both ends for better strength for the stressed tubes
ottoman
Postby ottoman » Tue Aug 21, 2012 12:32 am
Cant see in the pics but we snap a chalk line on the table to keep everything in line and use a few plumbobs. I also use a cheap laser level to make sure the rear wheel is parallel to the front wheel.
I machined up a couple of soild spacers to replace the motor mount bearings the stock Zuma uses and we made up a pair of simple mounts and once every thing was squared up and level I welded it up.
You get an idea of how long it really is... theory was to move the motor back but keep the rider in the stock position to keep weight on the front and reduce the tendency to wheelie... so far it has worked as intended!
ottoman
Postby ottoman » Tue Aug 21, 2012 12:40 am
Since we decided to run a Honda Elite body we started to bend up the tubing to support the body, seat and rear strut.
Nicks pretty good with the bender
Tube is .045 wall DOM
Tubing fits pretty good!
ottoman
Postby ottoman » Tue Aug 21, 2012 12:44 am
Time to mock it up for a idea of how it will look.
ottoman
Postby ottoman » Tue Aug 21, 2012 1:09 am
More tubes.. Fuel tank mounted
Tok a piece of .125 wall aluminum tubing I had laying around and machined up some end plugs, drilled an tapped for 5/16 heim ends for the rear strut.
Notice the crazy carb angle.. yes it works fine like that!!
Radiator mounted... seat mount tube installed
ottoman
Postby ottoman » Tue Aug 21, 2012 1:20 am
Seems like we mocked it up a hundred times to get everything to fit right...
Notice lower engine strut bar we added
First test passes... no foot pegs yet... no down tube or nitrous..77cc with Stage 6 R1400pipe.. since upgraded to 86cc with a Roost pipe
waxhead
Postby waxhead » Tue Aug 21, 2012 1:52 am
Very Cool.
I like it, any vids of it going
I dont have a short temper just a quick reaction to bullshit. Seeya !!!
Easy on the paint, hard on the porting
Thanks to my sponsors and team mates
roost exhausts
shark leathers
sava tyres
Dr Pulley
ottoman
Postby ottoman » Tue Aug 21, 2012 2:48 am
190mech
Postby 190mech » Tue Aug 21, 2012 4:29 am
You guys do some darn nice work!! :D
Postby zombie » Tue Aug 21, 2012 9:20 am
Rock Stars is what they are. I love the whole project.
I can believe the carb runs at that angle... Insane!
ottoman
Postby ottoman » Tue Aug 21, 2012 12:21 pm
Couple more....
Enviromoto
Postby Enviromoto » Tue Aug 21, 2012 8:43 pm
zombie wrote:Rock Stars is what they are. I love the whole project.
Oh geeze. Now he'll never get his helmet on. :P
Postby zombie » Tue Aug 21, 2012 9:00 pm
Sorry Buba! I just watched the Utube vid again. Goose bumps...
Users browsing this forum: No registered users and 5 guests
