Engine drain hose leaking oil
floyd2133
Postby floyd2133 » Mon Jun 20, 2016 10:14 pm
http://49ccscoot.proboards.com/thread/1 ... oil?page=1
the link above is the original thread with a lot of pics on my issue please see
new 100 cc bore kit muffler piston carburetor the works. just one problem. I have a leak from a drain hose from the top by the valves.
it's the black hose that leaks not the grey one
Read more: http://49ccscoot.proboards.com/thread/1 ... z4CB5nKkWKImage
Re: Engine drain hose leaking oil
Postby Areomyst » Tue Jun 21, 2016 10:41 am
It's not really a drain hose - it's supposed to re-route back to the inlet system to catch oil vapors and it's part of the PCV system. I see you have an aftermarket air filter, so plumbing that line back into the filter duct isn't really an option for you... I would look for a small powersports oil catch can, and make sure you have a filter on the end of the can that opens to the atmosphere.
I've got photos somewhere of an oil catch can that I put on my friend's Ruckus, but I don't have time at the moment to dig around for it... If I stumble across the thing I'll post it up!
floyd2133
Postby floyd2133 » Tue Jun 21, 2016 6:15 pm
It was the cap that goes over the valves. It needed the interior cap that goes over the little maze inside the cap that goes on to the valve assembly. Stupid me easy fix.
Postby Areomyst » Wed Jun 22, 2016 9:48 am
floyd2133 wrote:It was the cap that goes over the valves. It needed the interior cap that goes over the little maze inside the cap that goes on to the valve assembly. Stupid me easy fix.
I'm glad to read that you got the problem repaired to your liking. If you are going to leave the other end of that hose exposed to the atmosphere, you should still use an oil catch can and a filter on the atmospheric end.
floyd2133
Postby floyd2133 » Wed Jun 22, 2016 3:12 pm
Postby Areomyst » Wed Jun 22, 2016 9:32 pm
Did your valve cover not come with the plate on the inside or something? Odd.
