Neat Piston Circlip Tool
Post questions about anything from latest and greatest automatics, to the tried and true vintage scooters!
Moderators: SLOWRIDER, Areomyst, scootertrog
User avatar
Areomyst
Site Admin
Contact:
Postby Areomyst » Wed Mar 23, 2016 6:11 am
Hi guys!
I was browsing the web a while back, and found a pretty neat piston circlip installation tool. Generally, I prefer the clirclips with a tang - a "G" shaped circlip more or less. They're easy to install and only take a second with a pair of needle nose pliers. That said, some of the cylinder kits (and OEM parts too) come with a simple "C" shaped clip. I have always done okay installing those with a little brass pick that I have kicking around the toolbox, or even just using my thumbs (it builds calluses!). There are times thought, where it'd be nice to have an easier and more straightforward tool to get the job done.
Without further ado, check out this circlip tool! It's pretty neat, and if you're doing a lot of engine builds I think it can be worth the investment:
https://www.youtube.com/watch?v=lgB2WoQbt_Q
http://buxtools.com/
All the best,
~Josh
"The more a man learns, the more he realizes how little he knows."
User avatar
scootertrog
Re: Neat Piston Circlip Tool
Postby scootertrog » Thu Mar 24, 2016 8:49 am
Neat idea and well worth the $44. I can't tell you how many times I've laid on the garage floor with a flashlight searching for a stupid circlip, lol.
greg531
Postby greg531 » Sat Apr 02, 2016 1:28 am
But, that is $44 for every size....10mm, 12mm, 15mm...2 stroke, 4 stroke.....
I guess if you work on scooters every day, it would be worth it.....
When I install those clips, I barrow a old sheet from the wife, and use it as a tent, so if they do fly, the flight path is blocked!
1963 Vespa GL-150
2009 Aprilia Scarabeo 200
2005 Typhoon with:
70cc Corsa Kit
Laser Pro-X exhaust
4.0 gram Dr. Pulley sliders
20.5 Delorto carb
80 jet
Return to “Scooter Workshop”
Who is online
Users browsing this forum: Bing [Bot] and 6 guests
