Piaggio Typhoon has no spark!
greg531
Postby greg531 » Wed Jun 24, 2015 9:32 pm
I went to fire up my 05 Piggie for the club ride, and it didn't want to turn over very well.
I got it going at high rev's, and it didn't want to idle.
So, I worked on it yesterday, and it didn't have very good spark....it sparked maybe twice, the first time cranking it....It did that a few times, but didn't want to spark any more.....
I replaced about everything, coil, CDI, spark plug, etc....and still, no joy.....replaced the ground, even....
Does anyone have a clue what is wrong?
1963 Vespa GL-150
2009 Aprilia Scarabeo 200
2005 Typhoon with:
70cc Corsa Kit
Laser Pro-X exhaust
4.0 gram Dr. Pulley sliders
20.5 Delorto carb
80 jet
Postby dan v » Fri Jun 26, 2015 7:30 am
greg531
Postby greg531 » Sun Jun 28, 2015 7:49 pm
Thanks Dan....Great find....I will play with it when I get some time.....
1963 Vespa GL-150
2005 Typhoon with:
70cc Corsa Kit
Laser Pro-X exhaust
20.5 Delorto carb
80 jet
Postby dan v » Tue Jun 30, 2015 6:16 am
Great info on the PedParts blog. Bookmark it! :D
greg531
Postby greg531 » Tue Jul 28, 2015 10:17 pm
Got the Piggie going......The fault was in a really weird spot......Now, for the 20.5mm carb....got to keep up with the Jones!
1963 Vespa GL-150
2005 Typhoon with:
70cc Corsa Kit
Laser Pro-X exhaust
20.5 Delorto carb
80 jet
greg531
Postby greg531 » Fri Jul 31, 2015 12:53 am
By the way, we found the short in the rear Brake light switch...go figure!
1963 Vespa GL-150
2005 Typhoon with:
70cc Corsa Kit
Laser Pro-X exhaust
20.5 Delorto carb
80 jet
Postby Areomyst » Wed Aug 19, 2015 9:48 pm
greg531 wrote:By the way, we found the short in the rear Brake light switch...go figure!
That's odd. It caused a no-spark situation?
Speaking of oddities (and de-railing this from the topic), one of my clients brought me an Aprilia Mojito with a Morini engine a while back. I fixed it up, installed a Malossi cylinder, tuned it on the dyno, etc... He rode the bike, and was over the top happy with it - but he says he gets an electrical shock through the brake handles when first taking off in the morning. I've never heard of that in all my years wrenching on scooters... The bike is far away from me, but I'd like to get it back and solve that problem.
greg531
Postby greg531 » Thu Aug 27, 2015 2:57 am
When you unplug the 4 prong wiring from the stator, it would start on the battery, I have a friend with a pin puller, and start pulling the wires one at a time, til we found that the green wire was causing all the problems, and tracked it down to the brake light switch.
You do have to pull on the brakes to get it started, so that switch does more functions than the brake lights....
1963 Vespa GL-150
2005 Typhoon with:
70cc Corsa Kit
Laser Pro-X exhaust
20.5 Delorto carb
80 jet
